The second item you might get cheap on ebay is the contactor. There are expensive contactors, not by Tyco. The cheaper Tyco is LEV200 A4ANA. $79 at KTA services. The more expensive is EV200AAANA, $129. The differance is that the second has built in circuit that reduces the coil drain to .13 Amp, once the contactor closes. Also, a larger input voltage range. 9-36 volts. I don't think that part means anything to us who have a 12 volt battery on board. I got the better one for about $70.
