The remaining parts are sold by many companies. The best prices I found were from Revolt-ev.com. Nice people. You can compare:2/0 cable: $2.84/ft, Orange colored traction circuit is now being standardized. heatshrink tubing, 3/4 in.,4 ft. probably the right amount for one car. $2.53/ft. Anderson SBX-350 connectors. These are hermaphroditic.(the same at both ends) If you have batteries in front and back, you need 4, If you have one pack, you need 2. $10.18 ea. Heavy Duty copper lugs: Warp-9 motor, Rev NA, needs 4 at 1/2 inch hole. ($1.89 ea)Rev N reqs 3/8 inch hole. ($1.77 ea)Check your battery terminal dia. Boots for teminals: red, $.76 Forget the idea of "black" for the "Minus" circuit. Both wires are equally DEADLY!!
