Anderson makes a quick disconnect handle, meant to pull apart the Anderson connector, from the handle mounted next to the driver, in an emergency. This is an absolute requirement, but I'm going to use the e-brake release handle from a Lincoln Town-car, that matches the e-brake handle on my e-brake, except I'll paint it bright RED! The cable goes into the batterty compartment. TRACTION POWER IS NEVER NEVER NEVER run into the passenger compartment
