Old 10-18-2010, 04:00 PM   #4 (permalink)
NeilBlanchard
It is the trailing shape that matters more to reducing drag. I would try doing some tuft testing to see what is happening around the 'A' pillars and the mirrors -- it is more complicated than you might expect.
I wonder if a triangular plate trailing from the underside of the mirror would help? By removing the air flow on one side, it might calm things down, and reduce the turbulence?
PaleMelanesian (10-19-2010)
