Old 10-18-2010, 09:12 PM   #10 (permalink)
miket
Originally Posted by NachtRitter View Post
Also bending a 'U'-shaped lip along the bottom of the skirt would help strengthen up the portion that is not going to be attached to anything...
Hmmm I only need the 1" of clearance at the front and back edges of the tires because that the part that would hit the skirt first when the tire turns. The top doesnt need to be built out much. The skirt could go down relatively vertical than gently curve in an inch between the middle and the bottom. The body curves inward going down and much more near the bottom so i would need the real curves at the front and back edges getting much deeper near the bottom.
The front edge is the bumper so i would want the curve in the gap and not on top of the bumper. Since the bottom goes in so much the bottom rear edge might have to be brought back close to the edge of the door, depends on aero angles.
