Old 10-19-2010, 04:01 PM   #282 (permalink)
Nerys
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
Originally Posted by slogfilet View Post
I don't think we can make the assumption that a given engine has the same X% efficiency for different fuels. Efficiency is not an inherent property of an engine, but also of its fuel and other environmental variables.
Thats my point slogfilet.
I believe my engine is NOT as efficient on the E10 mix hence why I am seeing such a larger drop in FE.
but its not an efficiency of the engine problem. its a compatibility of the fuel problem.
Dump diesel in you gas engine and its not your engine's fault it runs like crap.
"An engine mechanically adapted around E85 will be much more efficient as the video demonstrates. "
note he did NOT say its more efficient and certaintly not MUCH more efficient.
He said it was "almost as" efficient as the NON Ethanol based fuel. Though to be fair he was comparing it to "diesels" but the FE difference in gas and diesel engines on that scale (150/250 sized vehicles) is not much different and he is using an optimized V6 versus a V8.
ie he is doing a lot more than JUST optimizing for ethanol. he is using a small lighter engine as well.
