I'm not actually sure of the model number but it crimps from 6mm to 70mm sq cable. I used 70mm on my car and it worked great. Its hand pumped hydraulic and from what i can tell is a chinese copy of the more expensive models i've seen. I paid well under 100usd inc delivery. As far as i know a similar one is sold by harbor freight in the states.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
