Old 10-20-2010, 12:15 AM   #306 (permalink)
Nerys
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
Originally Posted by basjoos View Post
You can also strain the gasoline/water mix through a chamois leather "cloth" to separate the gasoline. Presoak the chamois in clean gasoline and it will pass gasoline, but not water. Pour off the water as it accumulates on top of the chamois.
hey basjoos got a question for you I know its an old post but I am rereading the entire thread in case I missed something as suggested
with the cahmois leather. LOOSE water is not a problem I have gotten very good at getting rid of that. What about water in SOLUTION. from what I understand gas can hold upto 13% water in solution.
will this method you describe remove THAT water? ie the water you can not see?
I have no idea exactly how much ethanol is in each batch of gas so I can not "weigh" the waste to know how much "water" is left in the fuel.
so I have no idea how much water I am putting in the engine. I WOULD wash long term if I could reliably remove the water so its safe for my engine.
