Originally Posted by mwebb
02 sensors can not see 02
oxygen sensors can not detect oxygen
02 sensors detect combustibles
Just because you can be obnoxious doesn't make you correct.
An oxygen sensor, or lambda sensor, is an electronic device that measures the proportion of oxygen (O2) in the gas or liquid being analyzed.
Oxygen sensor - Wikipedia, the free encyclopedia
Now read this.
How 5-Wire Sensors Work (Tech Edge)
Feel free to edit your comment at any time.
liquid water will kill the 02 sensor deader than dog poop
liquid water will kill the 02 sensor (or AFR sensor) deader than dog poop
when it cracks the thimble because of temperature shock [/COLOR]
So you're saying water that goes into the engine through the intake manifold, is compressed, exposed to combustion temperature and pressure, is going to pour out of the exhaust port as cold liquid and destroy the O2 sensor? You're a genius
