Thread: Eoc
Old 10-20-2010, 11:49 AM   #5 (permalink)
Soulster
Got soul?
Soulster's Avatar
Soulster - '10 Kia Soul Plus
90 day: 35.36 mpg (US)
100k POS - '01 Dodge Neon
I went looking for some diagrams and this is what I found:
ECM
1. ECM (Engine Control Module)
2. Manifold Absolute Pressure Sensor (MAPS)
3. Intake Air Temperature Sensor (IATS)
4. Engine Coolant Temperature Sensor (ECTS)
5. Throttle Position Sensor (TPS)
6. Crankshaft Position Sensor (CKPS)
7. Camshaft Position Sensor (CMPS)
8. Knock Sensor (KS)
9. Heated Oxygen Sensor (HO2S) [Bank 1/Sensor 1]
10. Heated Oxygen Sensor (HO2S) [Bank 1/Sensor 2]
11. CVVT Oil Temperature Sensor (OTS)
12. A/C Pressure Transducer (APT)
13. Fuel Tank Pressure Sensor (FTPS)
14. Fuel Level Sensor (FLS)
15. Injector
16. Idle Speed Control Actuator (ISCA)
17. Purge Control Solenoid Valve (PCSV)
18. CVVT Oil Control Valve (OCV)
19. Canister Close Valve (CCV)
20. Ignition Coil
21. Main Relay
22. Fuel Pump Relay
23. Data Link Connector (DLC)
24. Multi-Purpose Check Connector
Do any of these tell me what I need to interrupt? Location of what to snip?
I am wanting to do something similar to what Niner did: http://ecomodder.com/forum/showthrea...-xa-14767.html
Thanks!
