More cheap off topic: The vacuum pump for your power brakes: maybe $295 on line as a kit. But the pump can be bought new (it's your life) for $100. The brand is "Thomas"m vavios models. The model # ending in 22 pumps 22 inches of mercury. The Model ending in 18, pumps 18. I think ICE vacuum guages read about 15 #, so either will do. The #'s CDC 22 and 18, pump pressure AND vacuum. The model BDC22 is vacuum only. You know you only need vacuum. You also need a vacuum switch. I found one cheap on-line. It had the sealed bag, and the KTA Services P/N on it!
