Old 10-20-2010, 12:04 PM   #21 (permalink)
williamson
Circuit breakers are Airpax, 500 amps,, $175, at KTA services. But I must admit I don't see the need, as the fuse is called a "semiconductor" fuse. Let me tell you, that doesn't mean that we are passing 775 amps thru a semi conductor! That's SEMI! It means it was designed to protect semiconductor equipment, which can be damaged by a spike. So the fuse will blow quickly. The circuit breaker has a trip time, depending % overload. So does the fuse.
