Old 10-20-2010, 12:09 PM   #22 (permalink)
williamson
The Albright contactors: If you want to use one, they are more expensive than TYCO. But, first go to the Albright web and see how they rate it for Amps, not the rating published by the seller. The same goes for the rated voltage. I've seen 120 volt rated Albrights rated for 165 volts by a seller. Don't buy it, if you have over 120 volts.
