Thread: Eoc
Old 10-20-2010, 04:54 PM   #8 (permalink)
Daox
Originally Posted by dcb View Post
I would suggest try interrupting lead 2 on the CKPS or the CMPS signal (K80 or K82) and see if it dies cleanly with one or both of those opened (i.e. with a normally closed microswitch on the shifter like you suggested). My crankshaft sensor was easier to locate and tap into on the engine block end fyi.
Thats what I did with mine and I ended up with a check engine light (no other adverse effects though).
