Old 10-20-2010, 05:39 PM   #7 (permalink)
aerohead
radius
Originally Posted by Varn View Post
Excellent! You might try putting some radius on the front of the bed wedge. Or install some filler between the bed and and the cab.
Keep sharing.
Varn,I taped some tufts just behind the gap where I could watch in the mirrors.They laid flat against the aeroshell and basically straight back until higher up,where they started pointing into the lower pressure coming down off the roof portion.
It appears that the air just skips over the gap and keeps on going.The guys at tech inspection at Bonneville recommended the leading edge radii also.I'll do it but I don't anticipate any measurable gain.
