if you wanted to do a full cover cam back, would it be possible to make it sectional (3 or more pieces) almost in an accordion style ?
each piece from the roof would overlap the next piece in line as to avoid any parachuting.
this way, you could get the advantages of a full camback and still have the use of your trunk.
see weak mockup below
Im curious about your results.
plus, what sort of mpg are you seeing with no mods vs with ?
I have a 94 protege, 5 spd, no AC (from the factory) that Im going to be doing some aero mods to as well.
