Old 10-20-2010, 11:02 PM   #27 (permalink)
Nerys
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
well I had to kill a neutral kill switch once in an older car but that was because of a bad clutch. IE could not clutch to neutral so could not start the car or shift gear into 1st
so I disabled the switch put it in 1st and started it up. since this also MOVED the car as it was cranking (hence why the switch is their) I was able to get the car going and driving :-) (just had to get it down the street) you can clutchless shift and just turn if off to do it all over again if you have to stop.
a nice emergency way of moving the car if the clutch is hosed.
