Old 10-21-2010, 09:36 AM   #213 (permalink)
d0sitmatr
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
Originally Posted by brucey View Post
Dostimar: I don't' know about the newer (08+) transmissions in the 6 cyl legs and OB's, but the one in the SVX is transferable to an outback, and vice versa with almost no modding. Plenty of guy sare running SVX's with outback transmissions for it's 4.44 gearing. In fact, it might be worth looking into because the SVX came with a 3.54 or something like that. But it did have a different rear end than the standard sube one. And the 4EAT H6 OB's of my cars generation is the same +/- the gearing, but the center differential is different so it'd probably be easier to find an H4.
good to know, I hadnt heard that before. if I had known, I probably would have gone that route as there was 2 SVX near me for sale at the time for less than $1,000.0. maybe I could have just pulled the FD from the AVX and used it in the OB ?
zerhour
I never once considered turning the car into an RWD. mostly because of things I read on the OB forums, where the car has a fuse you cna pull that disables the RWD of the car, essentially turning it into a FWD. but that isnt much of an option as it is an emergency feature in case of a problem with your rear transaxle, and actually takes away your FE by quite a large margin.
but a RWD OB would def be an alternative. and a preferable one at that (for me)
