Old 10-21-2010, 03:41 PM   #83 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Piwoslaw View Post
From the instructions it appears that it is not mounted in the block's freeze holes, but there is a special port for it in a plastic coolant housing behind the engine. This technically makes it a coolant heater, but also eases installation.
What make & model is the heater ?
It might fit or they might do one for my V50 as well - I can't use it unless I have the car garaged though (it's sleeping outside).
Volvo wants a ridiculous amount of money for a block heater.
The EGR/coolant heat exchanger has no wires, so it's the easiest mod
I wonder if I already have that cooler, or could get it installed.
Which Peugeot models have it ?
