Old 10-21-2010, 09:10 PM   #52 (permalink)
slowmover
90 day: 19.36 mpg (US)
I don't think any of the trailing edges benefit from radii, nor do the bottom edges but, yes, everything on the leading and top faces besides that rearmost edge.
Crosswinds. Anything that allows wind to pile up against and push is deleterious to all measures of performance.
The wind literally stacks against a non-radiused edge.
A semi, traveling either direction, pushes a bow wave that can easily upset a trailer of non-aero design. It does not hit head-on, and is far longer than the semi itself. The wind is reversing directions many times over a short period on the trailer surfaces.
The bottom is not so important, granted, but ground clearance must be low for this to be in force. A square white box, on beam axles, with the usual high clearance and narrow roll center is nothing more than a target, in a manner of speaking.
As you run the roads note that truckers will inform each other of a slow moving RV, and that as they pass they will move even farther away from it. It would be no trick -- but evil -- to pass at a high rate close up. One shot, one kill . . . .
For the same reason that once crosswinds reach 25 mph or above you will see 5'ers and the boxes pulled over for the day. I've towed in 35-mph constant with gusts to 60 and hardly noticed the trailer as it was the truck that was being pushed.
I have somewhere a quote about radiused edges and trailers. I'll see if I can find it.
