Old 10-22-2010, 12:50 AM   #34 (permalink)
bestclimb
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Originally Posted by endurance View Post
Well,
I discovered there isn't a block heater available for the car (the only one manufactured only fit the 02 RSX and was discontinued in 04 or 05), so I'm going with a lower radiator hose heater. It'll be an easier install anyway. What about a magnetic oil pan heater, too? Redundant?
a radiator hose is a good idea for a couple reasons 1 it gives you heat immediately for clearer windows. 2 good circulation of heat in the engine. (Get one with a pump as your thermostat will be closed and prevent the warmed coolant from circulating well)
Magnetic ones are annoying, buy some high temp silicone and a heat pad. clean the bottom of your oil pan and apply silicone to the pad apply pad to oil pan and go to bed.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
