Originally Posted by darcane
Why the great concern over brake cooling? Most of the people here try to limit their brake usage enough that cooling shouldn't be an issue.
I've had problems with warped rotors and I just upgraded the calipers per technical service bulletin. Also the truck will sometimes be fully loaded which will put more stress on the brakes. Cant forget steep hills too. It just seems a bit odd to me that the rotors have vanes inside specifically for moving air and then seallng the tires up tight.
