I did read about the vss delay, and set it to 0.
As for the ferrous metal, I am guessing that the weights are not mild steel then, or maybe I just have it too far away, I have it about 1/4" away, if all else fails I will weld bolts as you did.
Could you post a pic of the finished product?
