I was referring to added vibration, my jeep makes many shakes and vibrations.
I believe I will weld the same setup with a slightly different bracket for the sensor.
Pushing it till you get a pulse sounds like a good way to get a 'ball park' figure, but wouldn't driving a long distance (such as 350-400 miles) then comparing to the mpguino be a more accurate way to set it rather than speed?
