Swapped out the PS fluid as well. The fluid inside was changed at one point. The ATF still smelled fresh and only has slight discoloration. Oh well, least I know I checked up on the maintenance and got little synthetic in the pipes.
I'll post back tomorrow to see how it does.
Also got the TR7 a little bit further along. I still need new e-brake cables, speedo cable, and reverse light switch. Also discovered the hose clamp on the radiator was loose and I've been slowly leaking anti-freeze out of the car... :-( Clamp is back on and I need to stop at the parts store tomorrow and pick up some more antifeeze. I'm kinda piss at myself for not noticing something so obvious and of course for dumping the antifreeze around the dirt driveway for the past few months.
