Old 10-26-2010, 01:08 PM   #8 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by tjts1 View Post
The over run fuel cut off is different on every car. On our OBD2 volvo manual it will only shut off the injectors if you take your foot off the gas above 2000rpm with the engine warmed up and keep them turned off down to about 1300rpm. There is also a 2 second delay built in.
I read in one of Christ's posts that he slows down to a stop by engine braking while keeping the kill switch button pressed.
Or you can disable you brake and flasher lights, like many European BMW owners. That takes the driving experience to a whole new level
