Old 10-26-2010, 06:12 PM   #3 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by cr45 View Post
Would it be possible to move your oxygen sensor upstream on the exhaust such that it only measures the exhaust on one bank of cylinders? This would allow you to run the air through the the non sparking bank of cylinders as normal.
I had thought of doing just that, in order to completely shut off one bank. Ideally, in order to have a more-or-less evenly running engine, you'd want to have -X-X-X-X, where the "-"s correspond to deactivated cylinders, and "X"s correspond to active cylinders. This is to maintain, as much as possible, the existing engine harmonic arrangement.
However, the problem with this approach, of shutting off a whole bank, is that my engine has a firing order of 1-8-4-3-6-5-7-2. That translates to a LRRLRLLR pattern. If I were to shut off one bank (e.g., the left bank), so as to facilitate using the O2 sensor on the other bank, I would have -RR-R--R, which looks very uneven, and could shortly lead to destructive bearing wear or even a snapped crank.
