larger LRR tires
...."Likewise. But on long highway climbs, anything to increase engine load and lower rpm would be great."....
i guess those are 4 x 100 wheels
so there are many wheels from various cars like Honda civic or VW A2 A3 or
Echo or .... early prius
which will bolt up so if you switch to a 15" rim with 185 60 15( or the largest that will fit in the wheel well without rubbing )tires in the LRR type
you will find a wee bit of what you are seeking .
the tiddly wink tires you have now are not helping even at 50 psi
