Old 10-27-2010, 10:03 AM   #4 (permalink)
EdKiefer
The problem with crank/cam sensors is its used for ignition firing and timing and you want spark to always work.
Plus its got to make the ECU throw codes and possible limp mode ,you don't want that .
As mwebb mentions ,the right way is interrupt injectors 12v power side .
