Originally Posted by dcb
I think we need a database ( a page in the wiki) of car models and proven effective kill switch approaches. Because if you only have to interrupt a signal level circuit, that is as trivial to do as it gets, whereas if you need to interrupt inductive loads (coil & injectors) then you might have to add a relay or two if you want nice tactile push button control over it.
I second this
There should also be a section for known issues for each kill method. For example, doing this-and-this works, but throws code number #...
What matters is
where you're going, not
how fast.
