Old 10-27-2010, 02:38 PM   #9 (permalink)
EdKiefer
Originally Posted by dcb View Post
I think ideally you want both ignition and fuel to shut off. This is what happens when you key off too. Leaving one running without the other creates other issues.
My tbi metro stumbled on if I only killed fuel. There was a lead from the distributor (camshaft sensor) that would cleanly kill ignition and fuel and not throw codes when that circuit was opened (with a nc microswitch on the shifter)
even my 97 saturn mpfi would stumble on and accidentally relight occasionally if only killing fuel. Here putting the nc microswitch in series with the crankshaft sensor worked perfectly, w/no codes.
My tdi golf needs the solenoid on the pump to be interrupted with a more substantial switch.
I think we need a database ( a page in the wiki) of car models and proven effective kill switch approaches. Because if you only have to interrupt a signal level circuit, that is as trivial to do as it gets, whereas if you need to interrupt inductive loads (coil & injectors) then you might have to add a relay or two if you want nice tactile push button control over it.
It depends what you want , if you still have engine turning with this kill switch you definitely want fuel injectors off and spark on . If you want a dead kill then just kill power to whole ECU with the PGM-FI power relay .
Which is basically same thing as turning key off .
On honda/Acura it will kill power to the injectors , fuel pump and ECU , just need wiring diagram .
