Originally Posted by d0sitmatr
most likely as with an auto if it starts to bog on you, the trans downshifts, with a manual, you could end up damaging the engine if you refuse to downshift.
thats the best reason I can come up with.
If they built it with special piston rings and cylinders as they do marine engines, then you could bog that motor down all day. I believe marine engines also use special bearings.
