Old 10-27-2010, 08:52 PM   #28 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Leadfoot View Post
If they built it with special piston rings and cylinders as they do marine engines, then you could bog that motor down all day. I believe marine engines also use special bearings.
Modern engines like my cobalt 2.2 won't bog like antiques because the computer doesn't allow it, I have driven off from 500rpms with rather minor bog, it just doesn't take off efficiently doing that.
I find it odd my 5sp cobalt is rated higher than the 6sp cruise, should have put in a double overdrive instead of short shifter me thinks.
