well if the vehicle has such negative camber it would scrub a lot less and save fuel/drag. But I don't think they mean change your camber on your stock vehicle and add these tires and you improved FE , handling yes IMO .
Also 3 deg is a lot of camber . You start to notice the lean on cars around past 1deg .
