Originally Posted by KamperBob
A pair of narrow 24" beds plus skimpy 24" isle to get between requires 6' width, inside.
KB
True but your upper body would still have a lot of room which may not make it seem so tight.
I just did a quick layout of that; With a 24" wide bunks, and at the current taper of the rear, there's 31" between in the front and 27" in the rear. But, I will probably taper the rear more so it
may not work out.
