Originally Posted by dpero
True but your upper body would still have a lot of room which may not make it seem so tight.
I just did a quick layout of that; With a 24" wide bunks, and at the current taper of the rear, there's 31" between in the front and 27" in the rear. But, I will probably taper the rear more so it may not work out.
Good points. Maybe I should have asked for clarification first what you meant by BUNK beds. If stacked then you'd crawl in/out so I'd want a wide. If not two stacked but just one each side but raised over say storage cabinets then I'd want extra isle to get up/down without catching a knee for example. Now that I think more about it, given reduced headroom in the rear maybe you meant twin beds (normal height). In that case they could be even closer maybe. They could lift up (hinged lengthwise) for storage access. Just thinking out loud some more...
Rock on!
KB
EDIT: Doh! Now it's obvious when I look on the site. Email notification doesn't show pix so I missed it. Clear now!
