Old 10-28-2010, 03:44 PM   #12 (permalink)
Allch Chcar
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Originally Posted by cfg83 View Post
jamesqf -
Could the same be applied to ICE engines? I mean ICE HP is also rated at kW :
[IMG]...[/IMG]
Or am I mixing electric apples with electric oranges?
CarloSW2
KW like HP is a measurement of Power output. It does not show the energy consumption which in watts is measured by the hour or kilowatt-hours.
ICE fuel economy could be measured in KW-hours per mile like Battery Electric vehicles but there should be a MPG figures for ICE posted as well. Battery packs are not yet larger in capacity than a gallon of Gasoline, which is commonly accepted at approx 33.5Kw-hours. The range per charge should be enough to give an idea of range for BEVS. MPG doesn't really apply to BEVs as it is a measurement of range per gallon, something that BEVs don't function on. Whereas MPG for ICE is required to understand their effective range.
-Allch Chcar
