Old 10-28-2010, 06:22 PM   #10 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by UFO View Post
I've run a 2005 "Cherokee" CRD for 50,000 miles on B100 and blends down to B20. I've, nor has anyone else I know, had such pump failures with the possible exception of the new VW common rail TDIs -- those are apparently failing because of the lack of lubricity in the pump diesel; no one running biodiesel blends has had a pump failure.
Biodiesel is a better lubricant for the fuel pump than regular de-sulphured diesel.
It's one of the advantages of using blended diesel (B5 at the moment in the EU) over straight fossil diesel.
