Old 10-29-2010, 04:07 AM   #17 (permalink)
tumnasgt
tumnasgt's Avatar
The Charger - '15 BMW i3
I just had a bad thought: I doubt these will pass inspection, as they will not have low beam patterns...
Not only will they not pass inspection, but they will dazzle other drivers while providing less than ideal illumination of the road.
If HID kits are legal where you live, they are a much better option. Otherwise, replacing interior (eg instrument cluster) and position marker bulbs with LEDs will probably save just as much power without breaking any laws or putting anybody at risk.
EDIT: I see that you are in the UK, where ECE vehicle lighting regulations are in place. Aftermarket HIDs are not legal, as halogen headlamp housings are not set up for auto-leveling which is required for HID lamps. LED bulb replacement (for all but your headlamps) is your best option.
