Is your Aveo a Stick or automatic? If automatic did you account for the transmission cooler that runs through the radator. A cars automatic transmission fluid typically uses the radiator to cool its fluid. trucks with towing packages have a small external cooler that is bolted in front of the radiator as well.
When thinking and inspecting that also take note of the air conditioning condensor that needs to breathe also. i know we are entering cooler months but a new Aveo that is under warranty may get in troule if they see a "mod" that may have caused your trans fluid to wear premature or a AC unit that is not cooling to spec de to an overheating condensor.
I have not looked under the hood of an Aveo, I am relying on general auto knowledge. Just inspect your car before relying on what looks good as compared to function.
