Thread: Grillblock
Old 10-29-2010, 06:31 AM   #14 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Angelus359 View Post
I was wondering if a grillblock behind the plastic grill would be effective?
They're still effective - most car manufacturers use them nowadays to block their unnecessarily huge grilles.
It'd be a lot better if they dumped those fake grilles alltogether and go for a smooth front.
All the grillblocks I've seen online go infront of the grill.
That's often the easiest way, though not always the most visually appealing.
Other folks run blocks behind the grille, some have filled in the space between the grille frames.
I'm talking about blocking 1-2 inches behind the plastic grill, but several inches infront of the radiator.
I just made a trial grillblock out of ductape and cardboard, and placed it back there...
It should work, though it will probably work a bit better when you move it nearer the grille (less air seeping through other gaps).
I have no real way of testing it.
If you often do the same stretch of road at the same speed, you know what FE to expect.
Over time, it'll also show up in your long-term FE numbers.
The Following User Says Thank You to euromodder For This Useful Post:
Angelus359 (10-29-2010)
