Mine is fully 100% blocked if the daytime highs are below 80F. Above 80 I open 1/4 of the grille.
The more efficiently you drive, the less excess heat there is. This morning, for example, was 40 degrees here. I finished the drive 12.9 miles later with the water temperature at 182F - not quite fully warmed up.
