Thread: Eaarth
Old 10-29-2010, 03:18 PM   #57 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Weather Spotter View Post
Tell me now which one we are in?
You can grab them off wikipedia if you don't want to drown in data.
We're in an interglacial warm period - and have been for the last 12000 years or so .
It's a lot warmer and we have had good conditions for mankind to flourish into billions of specimens.
But in the very long run - think 10s of thousands of years - it's not going to last.
It never has.
This warm period could last another 5 or 10.000 years, or maybe just 500 years longer ... no-one can tell.
So we're heading back to an ice age in due time.
The Vostok Ice core data :
All we can see from these historical data, is that these Warm periods come about quickly in geological terms, then fade away over 100.000+ years before a new dramatic rise in temperature comes about.
Compare them to a very rough and uneven saw-blade .
CO2 follows the temperature trend, rather than leading it.
It's quite ridiculous to state the rise in CO2 is now caused by mankind as it'd leave no explanation for how things happened in the past.
The rise in temps started well before the massive proliferation of mankind and man's excessive use of fossil fuels.
The start also coincides with a previous glacial low - matching the previous warm periods.
Nothing unusual there.
Then there's of course variations within this long warm period.
Times when it's warmer (like now) and times when it's cooler (the Little Ice Age)
Looking at that graph, the bigger trend is already down towards a colder period despite the fact that the shorter term trend shows a serious increase in temps.
But it can happen fast.
In the short run (centuries) we're in a slightly warmer era within the warm period (comparable to the Medieval Warm period), and after that's over we'll probably be heading back to another so-called Little Ice Age.
Think of it as 3 oscillations, each on top of the other, with each getting less severe.
Man's greatest mistake is to think that everything should remain constant.
It doesn't. It doesn't at all.
Why did 30-40 yr ago people get freaked out about global cooing?
Because they were misled by the same kind of people who are misleading them now about global, manmade climate change.
Alarmists will always need to come up with bigger threats.
The next one always needs to be bigger than the previous one.
People laugh at Jehova's witnesses who've predicted the end of the world multiple times.
In due time the same is going to happen with the climate researchers.
Nobody really knows what drives climate changes.
Trouble is, admitting that openly, and admitting you can't change the change, means their excessive funding will vaporize.
Question is wether we need to know, 'cause we might try some short-term solution that messes up the really long term scheme of things.
The glaciers are melting !
They have been melting for some 12.000 years.
Other glaciers have melted before them.
In many regions it's how the land was landscaped.
The seas will be rising !
Workers have found shark teeth less than 60feet deep and 2 miles away from here, while digging a canal.
We're over 30 miles from the - current - coastline.
Do you know any sharks with feet ? I don't.
Some 2000 feet below, is a very thick chalk layer almost entirely made out of sea creatures.
It resurfaces famously on the Channel coast, as plaster of Paris, or in the Champagne, and with less aplomb north of the Meuse some 60 miles south.
Damn, the whole of Europe used to be a sea !
if Evolution is true (not in my Book, the Bible) then you have a 4-5 Billion year old planet so I need to see 1 Billion years of data
There's half a million years above in the Vostok graph, you'll have to make do with it.
This sort of timescale simply can't be grasped.
It's hardly 200mm long.
If one lives to be 100 years, that's hardly 1/4000 of the elapsed time.
Or hardly the equivalent of the thickness of a hair.
Earth itself is some 10.000 times older again ...
Why stop progress?
Are we really making progress ?
Looking around, I think we're only making a much bigger mess.
Believe what you want to but DO NOT force me to change for your belief.
How many people were - and still are - forced to change for your belief ?
The Following User Says Thank You to euromodder For This Useful Post:
Weather Spotter (10-29-2010)
