Originally Posted by Daox
The differential gear is removable, but the gear on the shaft is cut into the shaft, and you can't use a 4 speed shaft on a 5 speed transmission.
And there's the rub. I've been looking for an answer to this question for some time. Thanks.
It's really a shame. It probably puts re-gearing out of the realm of possibility. I'd have to source a c151 and a c151 donor to take the gears.
