Originally Posted by ami8i
I don't know if your 'new' injectors are P&H type. I know the older BOSCH Mono jetronic SPI with a low Z injector. BOSCH added a resistor (5 Ohm or 10Ohm??) to lower current. If you want I can ask a well educated AX/106 guy with MA3.0 ECU.
If it's possible it's better to pick up the signal before the driver because there is is nearly a square wave.
»Horst
Horst,
Thanks for that info. If you could ask the person who knows about the MA Ecu I'd be most grateful
