Thread: 1st Inch
Old 10-29-2010, 06:18 PM   #4 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Winter is registering on my mpg gauge, especially when it comes to lean burn. Set your grille block to "winter", set your heater to "cold" until your SG tells you it's okay to let coolant into the heater core, and before you get too depressed about your FE in the coming weeks, look at your logs from last February.
