Old 10-30-2010, 08:50 AM   #3937 (permalink)
jackbauer
jackbauer's Avatar
the new build continues. Hope to do final testing and assembly this evening. Note the two resistors and schottky diode used on the igbt drive and the shorted gate to emitter pins on the high side for use as freewheel diode.
ID:	7239   Click image for larger version
ID:	7240   Click image for larger version
ID:	7241   Click image for larger version
ID:	7242   Click image for larger version
ID:	7244   Click image for larger version
ID:	7245   Click image for larger version
ID:	7246   Click image for larger version
ID:	7247   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
mrbigh (10-30-2010)
