Originally Posted by hu_man
I have a megasquirt system that will go on the throttle body that came off of a suzuki tl1300 V twin motor. I morfed the two throttle bodies into one. I do not remember the size but it must be about 44mm atleast, the motor made 130 hp so one should work fine on the 848cc motor. I will add a coil pack ignition once the fuel system kinks are work out.
Hugh
Sounds like an excellent project. Megasquirt is a beautiful thing
