You are planning to split enough wood to run your truck on?
You are looking for efficiency, yet you live an hour from everywhere and drive an F150?
Moving and/or buying a different vehicle might make a lot more sense. What are you carrying with you that makes you need an F150?
Is splitting wood the most profitable thing that you can be doing with your time? How many dollars worth of fuel will you replace if you spend an hour splitting wood? Have you done a cost/benefit analysis to determine if this is the best use of your time?
