there there a max temperature difference it can generate? Could be an issue if it gets too cold out. I know the hot side can only reach 100ÂșC, maybe 150 if you get a nice one. You should dig up a datasheet on it. Ceramic heaters run much hotter than that, helps transfer heat quickly to the air.
